Tunnel Adjacency processing on specified slot logged a message of severity 'Error'.
If the error message indicates no memory on the system, remove some configuration on the system may solve the problem. Other error messages usually indicate software error, which should not happen in normal operation. Contact technical support with "show tech" output.
Error
%Parameter%
| Name | Type |
| slotNum | Slot |
| Parameter | Printf |
